I own the GA-EP35C-DS3R (bios F4) motherboard from gigabyte for about 2.5 years now, with 2GB of ddr3 ram, and I would like to jump into its maximum potential of 4GB ddr3 ram.
I would like to know if F3-10666CL7D-4GBRH (ripjaws) are supported and compatible for a possible overclock.
I am running Windows 7 32-bit edition, and my current RAM is causing me a few problems while trying to overclock. These issues did not appear when I was using win xp, but only appear in win 7. So, since I will be running win 7 32-bit I need to know if the ripjaws I mentioned will work flawlessly.
However, in case of not being supported, can you recommend me another product of yours that will give me 4GB of ddr3 ram?
