Well, let me start off by saying that I am fairly a newbie when it comes to OC but I have built hundreds of PCs over the year but only started OC recently.
So I got two of these G-Skill kits from Newegg (for total of 8GB) and Asus M4A89GTD Pro and x4 965 Black Edition C3 last week. I got the system built and left everything in BIOS as default and installed Windows 7 x64. That went find. I installed all drivers including the latest BIOS update.
Then I started to have some fun with it. I clocked it at 3.9GHz (200x19.5) and that seems OK on Prime for about 15 minutes. I had tried 4GHz (200x20) but Prime rebooted the machine almost instantly. So i stuck with 3.9GHz.
I set the RAM to 1600 since BIOS only saw it as 1333. I know that this was made for Intel kit but I bought seeing the reviews from NE since I wanted 1600 and not 1333. So I set that in the BIOS and tried everything I read on forums including upping 0.1V, 7-8-7-24 2T, 7-7-7-24 2T and even reset BIOS to default and not even touch anything in it so basically no OC whatsoever and RAM left running at 1333 9-9-9-24.
The problem is when I run Prime after about 15 minutes or so then one or more of the workers would stop. I don't remember exact message why they stopped.
I would expect Prime to pass with flying colors with absolutely no OC.
At this point I am so disappointed and not sure what to do. I popped is 2 sticks of F3-10600CL9D-4GBNT and running Prime on that now to see how that goes.
I am hoping that the 4 sticks are fine. This is my first time using G-Skill. Have always used Corsair, Kingston, Crucial and OCZ in past with no issues and I don't remember the last time I had a bad stick of RAM.
Any help would be appreciated.
Vince
Vince
