I have asked this question around and keep getting conflicting answers. I need to try to find some compatible memory for the sticks I already have. I am currently running G.Skill Model F3-10666CL9D-4GBPK on a ASUS M4A78T-E Motherboard with a AMD PH II X4 965 CPU. Since that memory type (F3-10666CL9D-4GBPK) is no longer available what would you suggest I can use to add an additional 4GB (for 8GB total)?
Would the F3-10666CL9D-4GBNQ work even though the voltage is 1.5v where the 4GBPK is 1.65v?
