My thread title may seem a bit odd, but read further to understand my issue.
I now use a MSI 890FXA-GD70 motherboard alongside a amd phenom ii x2 555 processor. After I tried to unllock two hidden cores on the CPU, my computer would no longer POST. I tried almost everything you could imagine to get it posting properly, but to no avail. Tried clearing CMOS, reseating, removing CPU, I even purified the DIMM and CPU sockets with rubbing alcohol and canned air to ensure the sockets were dry. Still the same issue.. 3 long beeps from PC speaker when computer tries to post. According to AMI Bios beep codes, 3 beeps means the bios has trouble reading the first 64KB of physical memory and to check memory modules. I checked my F3-14400CL7D (2 sticks, 2GB each - 4GB kit) sticks and nothing seemed off about them... the sticks didn't smell as if they burned (I would hope they didn't because I was running them at spec 1.65V and no higher!). I reseated the sticks on the first and second DIMM slots on the motherboard (the two furthest away, blue slots from the CPU wouldn't even give beep errors) and the issue still persists. I've never had to do an RMA with g.skill before. Is there a link or a phone number for me to call or refer to ensure I get an RMA request done properly for replacement units? Thanks to all who assist!
