been using this ram for a couple months, it's set to 1t in the bios of my m4a89td pro usb3. when i was using cpu-z in the past on the memory screen it always showed at 1t. i installed si software sandra last night and it was coming up as 2t. i made some timing adjustment in the bios, and now sandra says one chip is at 1t while the other is at 2t. the other thing that concerns me is that sandra says the bandwidth efficiency is only 47%. any help appreciated. hope i dont need to send these back for a replacement.
help F3-12800CL7D-4GBRH
Hello Bio,
Whatever you have the command rate set to in the BIOS is the command rate you're operating at.
CPUz sometimes has problems reporting out the correct command rate. Trust your BIOS or trust Everest. For me Everest always reports out the correct command rate.MSI Big Bang xPower x58
Intel i7 950
GSkill DDR3 2000 6x2Gb
Gigabyte GTX 460 x2 SLi
OCZ Vertex 2 SSD - OS Drive
Corsair TX950W
