Good morning to all,
I have got a P77P55D PRO with F3-10600CL8-4GBHK GSKILL memory modules, the processor is a core i5 750, all working under Windows 7 64. Since the beginning (end 2009), the system is very unstable: Following each cold boot, a BSOD appears very early. The only possibility to allow correct boot is to remove one memory module from its slot (PC powered off) and to re-plug it. But the problem comes back as soon as the system is re-launched.
The results given by MEMTEST86+ are very dark: Thousands of errors are detected. Installing memory in A1/B2 slots instead of A1/B1 give better results, but memory errors remain present.
The only stable configuration I have found is with two noname DDR 10600 2GB modules placed in A1/B2 (dual channel benefit lost).
My bios version is 1807. Both mother board and memory modules have been exchanged under warranty threw the retailer in France, without any improvement.
Why this G-SKILL DDR3 does not work with my mother board, despite it is given suitable in the QVL?
I would be very honoured if somebody from G-Skill could clarify this for me.
Thanks in advance and have a good day.
