I bought a PC with the following specs:
Asus P6X58D-E
CPU Intel Core i7 930
12GB Memory G.Skill 6x2GB F3-12800CL9-2GBNQ
No matter what I do, the RAM recognised varies every time I boot up. It goes from 4GB to the full 12GB (although very arerely), and I don't know what else to change in the settings.
I've tried may different voltages, moving the simms around, and checking the CPU pins and the fan screws, all to no avail.
Can you please help with a BIOS config that will work?
Here are details from CPU-Z
Intel Core i7 930
Windows 7 (Build 7600)
CPU Arch : 1 CPU - 4 Cores - 8 Threads
CPU PSN : Intel Core i7 CPU 930 @ 2.80GHz
CPU EXT : MMX, SSE (1, 2, 3, 3S, 4.1, 4.2), EM64T, VT-x
CPUID : 6.A.5 / Extended : 6.1A
CPU Cache : L1 : 4 x 32 / 4 x 32 KB - L2 : 4 x 256 KB
CPU Cache : L3 : 8192 KB
Core : Bloomfield (45 nm) / Stepping : D0
Freq : 1603.58 MHz (133.63 * 12)
MB Brand : Asus
MB Model : P6X58D-E
NB : Intel X58 rev 13
SB : Intel 82801JR (ICH10R) rev 00
GPU Type : Radeon HD 5850
GPU Clocks : Core 157 MHz / RAM 300 MHz
DirectX Version : 11.0
RAM : 12288 MB DDR3 Triple Channel
RAM Speed : 801.8 MHz (2:12) @ 9-9-9-24
Slot 1 : 2048MB (10700)
Slot 1 Manufacturer : G.Skill
Slot 2 : 2048MB (10700)
Slot 2 Manufacturer : G.Skill
Slot 3 : 2048MB (10700)
Slot 3 Manufacturer : G.Skill
Slot 4 : 2048MB (10700)
Slot 4 Manufacturer : G.Skill
Slot 5 : 2048MB (10700)
Slot 5 Manufacturer : G.Skill
Slot 6 : 2048MB (10700)
Slot 6 Manufacturer : G.Skill
Asus P6X58D-E
Intel Core i7 930
MB Brand : Asus
MB Model : P6X58D-E
