i have a macbook pro 2010 i5 ,looking to upgrade the memory from 4 to 6gb
question is can i used a new 4gb ram and left the old 2gb will they be compatible to work and
2nd is
will this work on my macbook pro?
http://www.newegg.ca/Product/Product...82E16820231265
or this (more expensive but seems the same????)
http://www.newegg.ca/Product/Product...82E16820231296
thanks support
2nd is
thanks support
