Ok, first of all, I've read ppl on the forums having the same issues with a similar system config, but i'd like to ask for a few more specific questions, since some of the users got answers through e-mail..
That's my config on the topic, AMD Phenom II X6 1090T, ASUS M4A89GTD PRO/USB3 and 8GB (2GB x 4) of F3-16000CL9D-4GBRH..
I started having Video driver not responding problem running games, and after a long research and trying different things, i found out i was really having memory compatibility problems. I tried different settings, instead of the original 3.2ghz clock i used 4.06ghz with 1800Mhz memory, 1600Mhz, different voltages and stuff.. Some of them showed some short stability, fixed the Video driver not responding, but started other issues, like random game crashes, freezes, blue screens.. I tried the original timing config, 9-9-9-27 and 1.65 volts, and again on this frequencies, 1600 and 1800, unstable..
Later on i loaded default configs on Bios, and left everything on AUTO, including voltages, timing, and every processor clock and voltages settings as well.. It seems that this was the config that the system got more stable, I still have the "driver not responding" problem, but it happens like only once, and the system turns stable again with apparently no further instabilities..
Please advise? I know this memory is not the recommendable one for AMD mobo, but i bought this computer from a friend, I really wish to find a solution without having to replace any components, even if that forces me to run the memories on a lower frequency.. All i want is a stable system for gaming purposes, but if possible please help me trying to find out the correct config to run them at the proper 2000Mhz frequency..
Thank you very much!!
