ASROCK P55 EXTREME + 8GB DDR3 2000 (Model F3-16000CL9D-4GBT)
  • ASROCK P55 EXTREME + 8GB DDR3 2000 (Model F3-16000CL9D-4GBT)
    Asrock P55 extreme
    Core i5 750
    4 x F3-16000CL9D-4GBT
    Windows 7 x64 ultimate
    What would be the BIOS settings for me to recognize the 8GB of DDR3 ram in 2000, and recognizing that the DDR3 1333(BCLK Frequency (MHz):133), and when I can I work on windows tells me DDR3 2000 8GB RAM (usable 3.99Gb), bios is updated to the latest versions on the website of the manufacturer.
    thanks
    You need to increase CPU VTT Voltage. If it is not enough, it will drop the memory controller and make it 4GB only.
      increased until voltage??
      thanks
        That is something you need to test, trial and error. It is different for each CPU, even of same model, so I can not help much with that.
          Get to recognize the 8GB of ram to DDR3 2000 with the following changes to the BIOS setup:
          CPU CLOCK RATIO: X20
          VTT voltage: 1.354
          CPU temperature in idle modules will retain 39 ? c, full load at 55-60 ? c
          will be good this configuration?
          thanks
          Memory Size 8192 MBytes
          Channels Dual
          Memory Frequency 999.6 MHz (2:10)
          CAS# latency (CL) 9.0
          RAS# to CAS# delay (tRCD) 9
          RAS# Precharge (tRP) 9
          Cycle Time (tRAS) 27
          Row Refresh Cycle Time (tRFC) 88
          Command Rate (CR) 2T
          Uncore Frequency 3198.9 MHz
          Technology 45 nm
          Core Speed 3998.6 MHz
          Multiplier x FSB 20.0 x 199.9 MHz
          Rated Bus speed 3598.7 MHz
          Stock frequency 2666 MHz
            Looks good!
