I'm using 2x2GB F3-12800CL7D-4GBECO on a Gigbyte 890XA-UD3 mobo with a Phenom II 555 BE CPU.
I set the memory to 1600MHz 7-8-7-24 at 1.32v and 1.42v (Giga won't do 1.35v)
It was not stable enough to run windows XP.
It did stabilize at 1.52v (apparently after a 30 minute ORTHOS stress test.)
I bought this memory because of its specs at low voltage.
Is there something special I need to do to get those specs, or are these sticks faulty?
I did a web search for answers but did not find one.
Is there a Gskill rep that can help me pronto?
I am under time pressure to get this machine working.
If I have to get the sticks replaced by teh vendor I need to return them ASAP.
Thanks in advance.
Thanks in advance.
