hi
i've recently bought asus p6t6 and two sets of trident F3-16000CL9T-6GBTD memory.
now, the problem is that there is no bios, only black screen and diag dram blue led on my motherboard is on and no beeps. After removing all memory modules there are beeps telling me that there is no memory detected. Next thing i've tried is using only one module in different sockets, same thing, blue led, no beeps and black screen, so i ended up trying all 6 modules separately in all sockets with same result.
So i suppose my bios (which is stocked, no updates) doesn't support F3-16000CL9T-6GBTD memory. If that is right, which bios version does support F3-16000CL9T-6GBTD memory but if i'm wrong and F3-16000CL9T-6GBTD should work with stock bios on asus p6t6 then what's the problem with my computer.
my cpu is i7 980x.
thank you
my cpu is i7 980x.
thank you
