Pi 1600 6-8-6-24
  • Pi 1600 6-8-6-24
    Hi guys,
    Got 2x2gb of this ram and I love it
    The question I have is I have run it at 1800 9-9-9-34 @1.76 but it wasn't a stable setting, my goal is to hit a 4ghz overclock with my 9550, what will be the magic numbers to get the ram to go 1:2 with a 475fsb??
    It's for a once off bench and once achieved it'll be run at stock. Oh mobo is a p45t-extreme
    edit: got the system to boot with 475fsb ( 6x multi so its just the ram oc'd )
    ram @ 1.6v 8-10-8-34 1900mhz
    NB @ 1.8v
    the rest manually set at stock so no "auto" hanky panky goes on
    anything i should change or am i on the right track?
    i get the feeling this ram isn't popular or hasn't been played with that much.
    not much info about oc'ing it on the net either
      The memory is rated for 1.60V, so 1800 9-9-9-34 @1.76 doesn't seem too feasible.
      This memory should scale something like DDR3-1900 8-9-8-27 1.65V
      You are on the right track, you just need to find the right voltages to stabilize.
        thanks for the reply
        have found out since i have a little problem with my mobo i need to sort out
        i run a p45t extreme mobo and i get a C1 error ( memory detect ) during cold boot unless mobo default settings are allowed to boot.
        this will carry on until the computer has been on for a while, i can then restart and boot from my 400fsb settings, but not more than that and be stable.
        tried f5g beta bios, f4 bios and will try the f3 tomorrow.
        all voltages and ram timings have been tried.
        all slots with single stick only.
        different combos of dual sticks has been tried.
        starting to pull my hair out :S
          So cold boot, 400FSB will not work? But after you restart a couple times it will work? Even one stick at a time has this problem?
          If so, send them in for new replacements as you should not have this problem.
