I have a GA-X58A-UD5 rev. 2.0 motherboard, an i7-980X CPU, and G. SKILL F3-12800CL7T-6GBPI memory (CL 7-8-7-24-2N), all brand new. I hooked everything up, and the first time the system came up it recognized only 4GB of the 6GB of RAM. The stock BIOS (FA, I think) was not acting 100% fine - when I went into MB Intelligent Tweaker, then into MIT Current status, the keyboard would stop working.
I then checked the Gigabyte forums, and see that the RAM issue is not rare, and usually caused by incorrect RAM settings. The thread I read recommended I upgrade to the newest BIOS, which I did (Fb10). After installing it, the system would go into areboot cycle where it would say it was "Recovering lost DRAM size," then reboot, then get the size error, reboot, etc. If I let the system keep rebooting for a while, it will eventually boot up, and I was able to install Windows 7 Ultimate 64bit. Windows states that there is 6GB of RAM, but only 4GB is usable. I never saw the "Recovering lost DRAM size" error with the stock BIOS version. Whenever Windows starts, it always sees 6GB of RAM, but only 4GB is usable.
The thread I read talked a lot about using XMP and then setting things manually. Basically, I am not really interested in overclocking the CPU right now, and clocking the RAM at stock is fine as well. I just want the machine to recognize all 6GB of RAM and to be stable. I did swap out the keyboard with a better one, and when I got into MIT again, it stated that the system had rebooted several times due to overclocking, so the values may not be accurate. I have tried fiddling with some of the values, but do not really know what I am doing.
Can someone talk me through the settings necessary to get the system reliable, or help me determine if I have a bad motherboard, CPU, or RAM? I am not familiar with overclocking, so bear with me if I ask basic questions. My feeling is that the problem is not bad hardware, but rather bad settings.
Thanks!
Thanks!
