Hi all, having recently decided it was time to upgrade my pc off i went to my local online store and bought myself the following:
G.SKILL Ripjaws 4GB kit (2GB x 2) DDR3-1333 (PC-10666) CL8-8-8-21 MEMORY F3-10666CL8D-4GBRM
AMD Phenom II X4 955 Black Edition Quad Core 3.2GHz
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD
Galaxy GeForce GTX 465 (Fermi) 1GB 256-bit GDDR5
as well as installing my existing copy of Windows Ultimate 64-bit version
I had things up and running for a few days but then started to get blue screen crashes with various errors being reported each time.
I can run the PC with one stick of ram in place but only in dimms 2/3/4 and cannot run 2 sticks in any combination and am left wondering if the problem lies with the motherboard or the ram settings (or indeed both in that they are completely incompatible!)
I am able to boot to memtest86 with memory in dual channel configuration and this came back with no errors after 6 passes.
Just wondering what the best settings are for this combination to keep things stable?
edit:
In addition to the information above,
here's what I've tried so far, with lots of help from dave76!!
Had minidump files analyzed, pointed to hardware issues.
Updated BIOS to F3A.
Bumped the CPU NB VID Control, added +0.1v.
When starting, at post screen emits 3 long beeps, boots to windows starting then freezes.
Problem only occurs with 2 sticks of ram, all is fine with just the one.
Bumped the DRAM voltage from 1.5v, to 1.54v, it started with both ram cards in, albeit briefly.
No bsod but pc keeps restarting after 30-60 seconds.
Bumped voltage to 1.6, ran memtest86 with 6 passes and no faults, seemed to be running stable.
After coming home from work, switched on, all ok for a few minutes then i got constant reboots.
Bumped the voltage to 1.65, get a few reboots then 3 long beeps then reboots and keeps on that cycle.
Could this be an issue with my Coolermaster RS-520W PSU?
Still can't get a single card to run in slot 1.
Appreciate any help with the settings or other suggestions.
edit:
