F3-16000CL6T-6GBPID with Gigabyte UD7
  • F3-16000CL6T-6GBPID with Gigabyte UD7
    The Gigabyte UD9 motherboard is recommended for this set. Does that mean the UD7 will not work with the F3-16000CL6T-6GBPID ? I have the UD7 and this memory and I can post with 6GB but only at 1.5v and 1333mhz. When I use the XMP "Profile 1" that sets the timings to the advertised specs I get no post. Any voltage or other settings i need to change that the XMP is not doing? QPI voltage?
    Yes, it is compatible. Yes, you need to find the right voltage for QPI/VTT Voltage. Once that is done, everything should work fine.
