Hi everyone..
I have recently purchased:
F3-17600CL7D-4GBPIS (2*2gb kit)
GA-P55a-ud3r (rev 1) F10
i5-760
venomous x
Corsair HX 650
I have installed my ram kit on DIMM1 & DIMM3. When I opened the XMP profile (CPU clock=13*220), the ram on DIMM3 is disabled in the bios occasionally. In Windows 7 64bit, it shows 2GB sometimes. If i reduce the BCLK to 200, 4GB is always shown correctly. The system cannot boot at ddr3 2200 if I only put 2GB in DIMM3. I left the QPI/VTT voltage auto And Easytune 6 shows QPI @ 1.41 v
I have already tried to reseat my CPU and the issue still occurs.
2GB is displayed when the ram modules are in DIMM 2 & 3 or DIMM 1 & 4. Don't know whether this is a mobo issue or not.
What should I do to get back 4GB at DDR3 -2200
i5-760
venomous x
Corsair HX 650
