System Specs
Mobo: Asus M4A785TD-v Evo (No 2T setting - only gripe)
CPU: AMD Phenom II x3 720 BE - revision RB-C2 *sigh* -(May eventually got to a 1090T x6)
RAM: G.Skill F3-10666CL8-2GBHK (2x2GB)
Down clocked 1066 Mhz; 8-8-8-20-27-1T (Thank you C2 stepping
GPU: Sapphire Vapor-X 5770 HD
PSU: OCZ ModXstreme-pro 600 Watt (or was it 650?)
OS: Windows 7 Home 64-bit.
Primary Question:
Newegg.com has a Very nice price on a possible upgrade I have been eyeing, specificly: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
But since it is diffrent then my original RAM, could I still downclock it to use both?
I don't mind running the ram at 1066 Mhz, if the timings make up for it. However I want to know ahead of time if I will have to pull the first 4 GB to add the 8 GB. I know 12 GB seems like a lot (My board specs to 16 max) but I would like a little extra so that I can play with VMware and RAM Drives.
I have found my current 4 GB of G.Skill to be wonderful (once I got past C2 steppping) and sufficent for my daily needs, such as gameing. But to keep enough for me, and still have some to room to play, its time for an upgrade.
Compatability advice greatly appreciated.
-Knave
Primary Question:
-Knave
