Here is my current setup
CPU - AMD Phenom II x6 1090t @ 3240 mhz
HT REF - 240
CPU NB(IMC) - 2400 mhz 1.25V
HT link - 2160 Mhz
MOBO - ASrock 890GX Extreme 3 bios 2.40
RAM Timing 7-8-7-24 40 2T
The ram I think is running ok. The problem is when I don't use my pc for about 8 hours or a day and when I boot it up my systems hangs and crashes.
I did a memtest 4.1 today 9 pass with no errors, also did occt linpack for 1 hour no errors. Then I turned my pc off for 4 hours but when I boot up in windows BSOD at once. i had to change the timings back at 8 8 8 24 and then back at 7 8 7 24.
Any advice for the timing 7 8 7 24?
or if I cant really ran my system on that timing ill use 8 8 8 24 but what CPU NB and volts should I use.
HT REF - 240
HT link - 2160 Mhz
