Hi all
My set up is as follows
CPU = AMD Phenom II X4 965 (Black Edition)
Motherboard = M4A89GTD PRO/USB3
Memory = GSkill Ripjaw (F3-12800CL7D) 4x 2gb
I had a lot of issues trying to get the system stable, and it seems to be a RAM issue. I bought this RAM because it was on the QVL for my motherboard however on further investigation Gskill dont have this RAM to work(well) on my motherboard (strange).
I had left it set to defaults and had some blue screen/screen locks
Default was Auto voltage and frequency of RAM 800mhz timing 9/9/9/24
I have tried setting to Gskills specification for the memory 1600mhz 7-8-7 (but i believe my processor can only handle 1333 unless OC'd) so i also tried 1333mhz 7-8-7 with 1.6 volt set manual.
All these set ups have been unstable, sometimes leading to pc not booting/not shutting down/crashing etc.
I ran prime and after 1 hour it had a rounding error. Using 1333mhz 7-8-7 1.6v.
So i decided to take 2 modules out, reset bios to defaults and leave it as is and it seems to be running really smoothly (2 + hours prime no errors) and 4-5 days of usage and reboots no errors.
Currently testing the two modules i took out and perhaps i have a faulty module(will take a while to see this).
But perhaps there is an issue of using more than 2 modules. And If i want to Run at 1600mhz is there an overclock i can do on CPU.
Thanks for reading hope someone can help me get my system stable and utilising my 8gb of Ram. Any other information you need i will do my best to supply
