Hi G.skill tech
currently running this config with stable linx 5hr
The DRAM Timing parameter adjusted in BIOS is set manual 7-10-10-1T. Adjusting any lower threw it off stability. Rest of DRAM timing on auto.
CPU Core = 1.4v
CPU PLL = 1.81525
QPI/DRAM Core = 1.4
DRAM Bus = 1.65625
Another set of F3-17600CL7D-4GBPIS is on the way. Planning to run at least 6GB triplet on this setting.
what can be tighten further here?
Kindly advice. Thank you.
CPU Core = 1.4v
CPU PLL = 1.81525
QPI/DRAM Core = 1.4
DRAM Bus = 1.65625
