I can't seem to get my system to operate with any degree of stability using 4 sticks of F3-12800CL9D-4GBRL (2 kits of 2x2GB). I can run 2 sticks at 1600 with no problems. As soon as I try 8gb, I start getting BSOD.
I have tried incrementing NB voltage up as much as .1 with no luck. I have also tried running 8gb at 1333 with no luck.
I have seen in other threads that this particular memory has had cold boot issues. Is it possible to only see this problem with 8gb installed?
Here are my system specs:
GIGABYTE GA-790XTA-UD4
Windows 7 x64
AMD Athlon II X3 435 Rana 2.9GHz
Antec TruePower TP-750 Blue 750W
2x SAPPHIRE Radeon HD 5750 1GB 128-bit GDDR5
2x G.SKILL Ripjaws Series 4GB (2 x 2GB) Model F3-12800CL9D-4GBRL
Windows 7 x64
