CPU: AMD Phenom II X4 955 Black
MOBO: ASUS M4A7XTD-EVO
RAM: F3-12800CL7D-4GBRM
I knew about the limitations with AMD CPUs for this particular set of RAM, but I don't really mind...
My problem is that I can't get the RAM to get passed 667 MHz (with 8-8-8-24 1T)
I emailed G.Skill with my problem and they said just bump the CPU-NB Voltage up to 1.2 and I should be able to run at 1600 MHz.... so I did that, and I can't even get to 1333 MHz!!! PLEASE HELP, the time for the RMA is almost up so I need to know whether I should send it back or not!!!!!
additional info:
FSB : DRAM is 3:10
NB frequency is 2000 MHz
running at stock speeds for everything
additional info:
FSB : DRAM is 3:10
