Biostar ta890gxb hd
  • Biostar ta890gxb hd
    I am considering purchasing a BIOSTAR TA890GXB HD motherboard and was looking at the F3-12800CL9D-4GBRL Ripjaws (2x2gig) modules. Would these be a good choice or would you recommend other types?
    This is one of our most popular kits because of it's price and value. Should work great in your system, although depending on your CPU, it may need a tweak to stabilize DDR3-1600. If you have any issues, simply let us know.
