Hi everyone !
I have just assembled a new computer about a month ago. I ordered the components and built the PC myself. The problem is, the damn things is super unstable ! Firefox crashes on a regular basis, Crysis has trouble loading levels and often does the ''Crysis has stopped working'' and i get blue screens of death (stop messages and memory dumps). The stop message i get the most is the 00X000000a1. I tested my HD, my ram (windows diagnostic found no errors with ram). I did try to but my ram in slot 2 and 4 but the computer would not even boot
I also tried to increase volt on ram but to no avail...
I have a few questions:
1) Is it 100% certain that this type of ram is compatible with that gigabyte Motherboard and AMD CPU
2) Can you help me try to put manual settings in the bios that might help?
3) Should I RMA right away...
Power Supple : XFX 650 watt
GPU : XFX radeon 5850
CPU : AMD Phenom II X4 965 Black Edition
Motherboard
: GIGABYTE GA-790FXTA-UD5 rev 1.
Ram : G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory
Model F3-12800CL9D-4GBNQ
Operating System: Windows 7 64 bit
Memtest86 version 3.4 results:
Chipset AMD K8
Settings Ram : 569 MHz (DDR113) Cas : 2.5-1-3-1/DDR-1 (128 bits)
ECC : disabled
Bits in error mask: ffffffff
Bits in error total : 32 min: 1
Max contiguouse error : 2
Error per memory slot : 0: 999999999
1: 2733
Test 7 errors : 5804
Test 5 errors : crashed while trying to figure out ....
Error confidence value : 109
Highest error Address : 000fffdde4e - 4095.8 MB
Prime95 test results:
Self-test 10k passed
Test 1, 4500 Lucas-lehmer iterations of m17432577 using FF length 896K.
Fatal Error : Rounding was 0.5 , expected less then 0.4
Hardware failure detected , consult stress.txt file
Torture test completed 34 tests in 47 minutes - 1 error - 0 warnings
Worker stopped
Motherboard
Chipset AMD K8
ECC : disabled
1: 2733
Worker stopped
