I'm having a hard time getting the memory to work on my motherboard, sometimes the Bios doesn't post, sometimes it posts, but windows fails to load, and other times I get a BSOD, sometimes the PC works fine for hours.
I've tried many settings I've seen on the internet but I can't get it to be 100% Stable. I was overclocking, but because of the problems i got rid of the overclock (CPU and settings back to default ) and I'm trying to get the memory stable, Any suggestions?, I'm desperate.
My goal is to finally overclock my system, but for now I'll settle for anything stable, I'm not sure why the pc it's so unstable (even without any overclock), I'm Considering replacing the modules for something else, but Hopefully we can get these to work.
here's the specs
here's the specs
G.Skill [ P I ] F3-12800CL6T-6GBPI (2Gx3)
Main Board intel
System Desktop
System Type DDR3
M/B Chipset Intel X58
CAS Latency 6-8-6-20-2N
Capacity 6GB (2GB x3)
Speed DDR3-1600 (PC3 12800)
Test Voltage 1.6 Volts
PCB
Registered/Unbuffered Unbuffered
Error Checking Non-ECC
Type 240-pin DIMM
Warranty Lifetime
Main Board intel
System Desktop
System Type DDR3
PCB
Type 240-pin DIMM
Warranty Lifetime
