processor: Intel Quard Core Q9660
Mainboard: Asus P5QC
G.Skill Ram:F3-12800Cl7D-4GBRM
OS: Win7 64bit
power supply 750w
I have no experience configuring RAM manually before. This is my first time. When it was default setting (9-9-9-24 DRAM volt = auto DRAM Frequency = auto), the blue screen appeared and showed physical memory dump. This is 1600 Mhz ram, but my mainboard can support only 1333Mhz. That's why I set at 1333 Mhz
After I looked at the forum, I reconfigured into this following
Current Setup 8-8-7-24 1.6V 1333 Mhz (This is 1600 Mhz ram, but my mainboard can support only 1333Mhz. That's why I set at 1333 Mhz)
With the current setup, the blue screen showing physical memory dump still appears sometimes.
I cant find the command rate timing on my board, do i need it?
I dont know what's wrong with it now.
If you have some other suggestion, please help me fill below.
Ai Overclock Tuner
CPU Ratio Setting
FSB Frequency
PCIE Frequency
FSB Strap to North Bridge
DRAM Frequency
DRAM Timing Control (Values in DRAM Clocks):
-CAS# Latency
-DRAM RAS# to CAS# Delay
-DRAM RAS# Precharge Time
-DRAM RAS# Activate to Prechage Time
-RAS# to #RAS Delay
-Row Refresh Cycle Time
-Write Recovery Time
-Read to Precharge Time
-Read to Write Delay(S/D)
-Write to Read Delay(S)
-Write to Read Delay(D)
-Read to Read Delay(S)
-Read to Read Delay(D)
-Write to Write Delay(S)
-Write to Write Delay(D)
-Write to Pre Delay
-Read to Pre Delay
-Pre to Pre Delay
-All Pre to Act Delay
-All Pre to Ref Delay
DRAM Static Read Control
DRAM Dynamic Write Control
DRAM Read Training
DRAM Write Training
MEM. OC Charger
Ai Clock Twister
Ai Transaction Booster
CPU Voltage
CPU PLL Voltage
FSB Termination Voltage
DRAM Voltage
NB Voltage
SB Voltage
PCIE SATA Voltage
Load-Line Calibration
Cpu Spread Spectrum
PCIE Spread Spectrum
CPU Clock Skew
NB Clock Skew
CPU Margin Enhancement
OS: Win7 64bit
power supply 750w
Ai Overclock Tuner
CPU Ratio Setting
FSB Frequency
PCIE Frequency
DRAM Frequency
-CAS# Latency
-RAS# to #RAS Delay
-Write to Pre Delay
-Read to Pre Delay
-Pre to Pre Delay
DRAM Read Training
DRAM Write Training
MEM. OC Charger
Ai Clock Twister
CPU Voltage
CPU PLL Voltage
DRAM Voltage
NB Voltage
SB Voltage
PCIE SATA Voltage
Cpu Spread Spectrum
CPU Clock Skew
NB Clock Skew
