GA-P55M-UD2 and F3-10600CL9D-2GBNQ
  • GA-P55M-UD2 and F3-10600CL9D-2GBNQ
    Hi. I'm a newbie to technical stuff. I've been having blue screens in windows 7 and a microsoft guy has suggested I check the RAM settings in the BIOS as the auto settings in gigabyte boards are not always correct. The crashes happen on 1st boot during startup. But if I shutdown, wait 10 secs and reboot, it all seems to work fine.
    Motherboard: GA-P55M-UD2
    Memory: 2 x F3-10600CL9D-2GBNQ
    CPU: Intel Core i5 750
    Graphics: 1 GB ATI Radeon HD 5750
    I haven't actually looked in the bios yet, but I saw some other threads refer to CPU-Z, so I installed that and it shows:
    DRAM 666.2 MHz
    FSB: DRAM 2:10
    CL 9.0
    tRCD 9
    tRP 9
    tRAS 24
    tRFC 74
    CR 1
    Does that mean everything's ok?
    Settings are fine. There may be a problem with one of the modules, send them in for new replacements and that should solve the problem.
    Thak you
      Hi. I did return the RAM to the company I bought the PC from. They swapped it for similar Corsair XMS3 modules and these seem to work perfectly.
      Cheers.
