Mobo: ASUS P6TD Deluxe
RAM: G.Skill NQ (G Skill F3-12800CL9-2GBNQ)
CPU: i7 930
PSU: Antec Quattro 1000
First of all, i'd like to say thanks for your time.
I'm having the issue that it seems thousands of people re having where only 4 GB of ram is detected on a COLD boot. When one leaves it as 4GB detected, the system is very unstable and will get a blue screen < 5 minutes.
This doesn't happen just on 1600 for me, but also on 1066 or 1333.
I must of read this page 50 times: http://i4memory.com/ramdetect/
Things i've done so far:
- Updated the bios to the newest version
- Mucked around with voltages over and over again (AI Tweaker posted below)
- Reseated CPU
- Rotated each ram stick
- ON morning, tested each ramstick cold in A1 to see if they would post, they did.
- Performed memtest -- crashed instantly when opening it. (rebooted) Should be noted, i've tried an ubuntu live CD memtest and a memtest downloaded and burned. Both had the same result.
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting…………………...............[16.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[200]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1603MHz]
UCLK Frequency.........................[3609MHz]
QPI Link Data Rate.....................[7218MT/s]
Timings: 9-9-9-24
REF Cycle Time: 110
FOUR ACT WIN Time: 38
DRAM TIming Mode: 2N
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.25000]
CPU PLL Voltage........................[Auto]
QPI/DRAM Core Voltage..................[1.35000]
IOH Voltage............................[1.30]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.40]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Auto]
CPU Differential Amplitude.............[Auto]
CPU Clock Skew.........................[Auto]
CPU Spread Spectrum....................[Auto]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Auto]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
CPU: i7 930
- Reseated CPU
Timings: 9-9-9-24
REF Cycle Time: 110
