System is in the sig.
This is my second attempt with this kit, as I just got my RMA replacements. The first kit exhibited the exact symptoms of the cold boot issue that's all over this forum (unbeknown to me at the time). On cold boot only 10GB of 12GB would be reported by Windows. Interestingly, though, Memtest 86+ in every case detected all 12GB and tested fine over multiple cycles. Problem was only in Windows. If the computer was then rebooted and timings changed in BIOS (sped up, slowed down, didn't matter), system would boot up and Windows would see all 12GB. I had no idea of the hot/cold nature of the problem until I read it in this forum, then started to test for it and found it to be the case. Until then, I just assumed it wasn't detecting the memory at all. Instead, restarting and changing BIOS settings would get things detected. (I've read other reports that restarting several times in succession would achieve the same result, but I always had to change settings to get it to detect.)
Tried using X.M.P. profile, and problem persisted. Tried using manual settings found elsewhere on this forum, and problem persisted. Tried using X.M.P. profile, but de-tuned to 1333mhz--no luck. In all cases Memtest would detect no problems, Windows would drop 2GB. Sent this kit in for RMA.
New kit came yesterday afternoon. Only had a short while to try it out, but this kit seems to be even WORSE than the last! Loaded X.M.P. profile in BIOS and it called for 1.9V VDIMM! Last kit's X.M.P. profile called for only 1.5V, so this didn't seem even close to right, and made me nervous considering I'm only air cooled. Nevertheless, I tried it; all settings to auto, X.M.P. profile enabled. System would not post. Restarted the machine, this time the system made it through post, but cut out at some point with a message that "overclock was unsuccessful," or something like that, and that I needed to load BIOS and change settings.
Entered BIOS and changed some more settings. Lowered VDIMM to 1.6V, raised QPI/DRAM to 1.35V manually. System made it through post, Windows loaded. Unfortunately, every time I tried to access any program, gibberish errors popped up. Clearly something was still amiss. Restarted the system, this time Windows worked fine. Except Windows was reporting only 8GB of RAM: I'm going backwards here...
This is as far as I've been able to get before having to go to work. Since obviously I'm going to have to try manual settings with this kit to come even close to getting it to work, can someone please suggest a list of settings that might make this kit behave in this system? I would appreciate it.
On a side note, is this just standard nowadays? I used to be a hobbyist system builder that built about a rig per month. By the end of that time (about four years ago), hardware, drivers, and Windows had gotten to the point that I could throw just about any hardware into a box, install Windows, and things were going to work right out of the box 99% of the time. No need to get too busy with BIOS settings, no need to hunt down drivers and flash BIOS to the latest version; things just went together and worked. Is the industry regressing, or am I just unlucky with this build?
And kudos to G.Skill for their excellent RMA policy and fast service. Apparently since I was last building a lot of systems Newegg decided to start shafting their customers and take the opposite approach, which is too bad...
