My system seems rock solid (at 1600MHz) with the settings below (500 consecutive runs of LinX error-free, max core temp 73C) but I, like many others on this forum it seems, cannot get it to run at 2000MHz. I had a very hard time to even get it to POST (had to really crank up the voltage for QPI, PLL, DRAM and really relaxthe timings from what they are supposed to run at), but even if I managed to get into Windows it crashes/reboots soon after. What am I doing wrong here?
CPU: i7 930
HSF: Noctua NH-D14
MOBO: Asus P6X58D-E (Bios 0108)
RAM: G.Skill Ripjaws F3-16000CL9T-6GBRH
PSU: Corsair HX850W
(Copied this list from another post and edited in my settings. Side note: is there a way to export BIOS settings to a text file?)
Ai Tweaker
Target CPU Frequency: 4200MHz
Target DRAM Frequency: 1603MHz
Ai Overclock Tuner [Manual]
CPU Ration Setting [21.0]
Intel(R) SpeedStep(TM) Tech [Enabled]
Xtreme Phase Full Power Mode [Enabled]
BCLK Frequency [200]
PCIE Frequency [100]
DRAM Frequency [DDR3-1603] <--- tried 2005
UCLK Frequency [Auto]
QPI Link Data Rate [Auto]
ASUS/3rd Party UI Priority [ASUS Utility]
CPU Voltage Control [Manual]
CPU Voltage [1.33125]
CPU PLL Voltage [1.80] <--- tried up to 1.88
QPI/DRAM Core Voltage [1.30000] <--- tried up to 1.6
IOH Voltage [1.30]
IOH PCIE Voltage [1.60]
ICH Voltage [1.20]
ICH PCIE Voltage [1.60]
DRAM Bus Voltage [1.64] <--- tried up to 1.66
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
Load-Line Calibration [Auto] <--- tried disabling
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
CPU Spread Spectrum [Auto]
IOH Clock Skew [Auto]
PCIE Spread Spectrum [Auto]
DRAM Timing Control
DRAM CAS# Latency [Auto] <--- tried Auto, 9
DRAM RAS# PRE Time [Auto] <--- tried Auto, 9
DRAM RAS# ACT Time [Auto] <--- tried Auto, 9
DRAM RAS# to RAS# Delay [Auto] <--- tried Auto, 24, 27
DRAM REF Cycle Time [Auto]
DRAM WRITE Recovery Time [Auto]
DRAM READ to PRE Time [Auto]
DRAM FOUR ACT WIN Time [Auto]
DRAM Back-To-Back CAS# Delay [Auto]
DRAM Timing Mode [Auto] <--- tried Auto, 1N, 2N, 3N
DRAM Round Trip Latency on CHA [Auto]
DRAM Round Trip Latency on CHB [Auto]
DRAM Round Trip Latency on CHC [Auto]
DRAM WRITE to Read Delay (DD) [Auto]
DRAM WRITE to Read Delay (DR) [Auto]
DRAM WRITE to Read Delay (SR) [Auto]
DRAM READ to WRITE Delay (DD) [Auto]
DRAM READ to WRITE Delay (DR) [Auto]
DRAM READ to WRITE Delay (SR) [Auto]
DRAM READ to READ Delay (DD) [Auto]
DRAM READ to READ Delay (DR) [Auto]
DRAM READ to READ Delay (SR) [Auto]
DRAM WRITE to WRITE Delay (DD) [Auto]
DRAM WRITE to WRITE Delay (DR) [Auto]
DRAM WRITE to WRITE Delay (SR) [Auto]
CPU: i7 930
HSF: Noctua NH-D14
PSU: Corsair HX850W
Ai Tweaker
IOH Voltage [1.30]
ICH Voltage [1.20]
DRAM Timing Control
