I was lurking around the Gskill forums looking for some BIOS settings and i came upon a post containing this picture. The owner had questions regarding RAM settings in bios for OC'ing. Not sure what the problem is, whether its the CPu difference or MB, but im basically getting half the bandwidth he is. Plus when i performed the windows experience index i only got a 5.9 with this memory. I previously tested with prime95, Intel Burn Test, OCCP, and all is stable...just feels kinda slow. Windows 7 X64 and Bios sees the full 4 gigs as well. Im frustrated because i dont know why i apparently have half the bandwidth. Anybody got any clues for a n00b? ![Confused](https://www.gskill.us/forum/core/images/smilies/confused.png)
Mine:
![](http://lookpic.com/d2/t2/2314/6hej5R.jpeg)
His:
![](http://lookpic.com/d2/t2/2608/8UmvCLUO.jpeg)
My System settings:
![](http://lookpic.com/d2/t2/3367/WLGtuLxX.jpeg)
My components are as follows:
GA-P55-USB3
Intel Core i3 530 2.93 with OC to 4.0
Noctua NH-D14 with custom Dremel mod
4GB Gskill F3-16000CL9D-4GBTD at 2000mhz
Nvidia Geforce GTX 285 1 GB RAM
Mine:
His:
My System settings:
GA-P55-USB3
