Hello, I'm Luca froma Italy. I have builded a new PC with
Gigabyte P55A-UD4 (BIOS version F10)
2X 4Gb ripjaws 1333 timing 7-7-7-21
Intel i7 860 no OC
radeon 5770 1Gb (if can be usefull this information)
I have set the timings by myself (7-7-7-21) other timings I have set on [AUTO], I'm not using XMP. And the other BIOS parameters are setted like I have readed in this forum.
The problem is that this configuration may not be stable, and the PC is restarting many times with BOSD (MEMORY MANAGEMENT).
I have made a lot of tests with memetest86, memtest (run under Wondows), and LinX:
- tested each ram stick alone
- tested 2 sticks toghether
- tested all 4 sticks toghether
And nothing is showed by any sofware
I've tried to change QPI/VVT voltage, but nothing. Now it is running with default settings
With "only" 4Gb of RAM the PC is stable
How I have to do for fix this situation? I don't think that there are some defective sticks
Please, I need Help.
Luca
Intel i7 860 no OC
Luca
