Hello there GSKILL Tech,
I know the ram is rated for 9-9-9-24 @ 2000, and so far most recommendations are for that on this board. I've seen varying recommendations from 1.55 to 1.65V. The set I bought said it was rated for 1.65V, although it seems sometimes you recommend lower voltages? I'm sure set to set some clock better, so can handle lower voltages.
I'm wondering if I were to try to run at lower speeds maybe say 1600. Would I be able to try CL7? If so what are your settings suggestions?
Thanks!
BTW I burnt in overnight at stock speeds, and am ready to try some more aggressive timings/clock speeds.
Thanks!
