I have a 790fx board with F3-12800CL9D-4GBNQ i set the timing to the 9-9-9-24 settings based on the listing on the side of the ram and some of the post i have read. my problem is this my system seems stable no errors i had it run straight for 3 days. only when i turn it off for a while about "24hrs" and the turn it back on i get bsod while windows is loading if i go in and make a minor change to bios it runs with no problem i think it might be a cold boot problem.
Any insight would be appreciated.
C1E: On
C&Q: Off
DRAM Freq: 800
Timings: 9-9-9-24 tRC:auto
Command Rate: 2T
DRAM Voltage: auto
NB Voltage: auto
HT Voltage:auto
MB Bios: 1.10
C1E: On
C&Q: Off
DRAM Freq: 800
Command Rate: 2T
DRAM Voltage: auto
NB Voltage: auto
HT Voltage:auto
MB Bios: 1.10
