register
CPU Clock Ratio - 21x
QPI Link Speed - AUTO
Base Clock Control - Enabled
BCLK Frequency - 133
System Memory Multiplier - 14
CAS Latency Time - 9
tRCD - 9
tRP - 9
tRAS - 24
Enter these for the other three as well.
Channel A Timing Settings
Advanced Timings
Command Rate - 2
Advanced Voltage Control
Load-Line Calibration - Disabled
QPI/VTT Voltage - 1.50V
