Hello, this is my first post in the forums so be easy on me, but I have an asus M4A785TD-V Evo running that I want to run 8gb of GSKILL F3-12800CL9D-4GBNQ. I have set the timings manually (see cpu-z screenshot) but when I install all 8gb windows will no longer start. When I remove a stick, it starts just fine with 6gb. I thought it was just a bad stick of ram at first, so I tried starting it with 6gb with a different set in each time and each time it started and ran great. Only when I put 8gb in would it not start. I have upgraded to the newest bios and also have tried running the ram at 1333mhz and it still does not work. Does it sound like I have defective ram? Or am I just missing something in the bios that I need to set up in order to run 8gb at 1600? Any help is appreciated.
M4A785TD-V Evo GSKILL F3-12800CL9D-4GBNQ 8gb memory problem
