Hi Gskill Staff!!
here is my problem...
bios is setted by stock as 1333mhz 1.5V and 9-9-9-24... When I change it to 1600mhz 1.6V and 7-8-7-24 it says something like im overclocking so i have to change bios again... I mean it doesnt start with that config :S
Do you know what is the bios config that gives me the highest stability and speed?
MotherBoard: Gigabyte GA-770TA-UD3
PC: AMD Phenom II X4 3.2Ghz Black Edition Stepping C3
RAM:2x2 Gb Gskill DDR3 RIPJAWS 1600mhz (F3-12800CL7D-4GBRM)
Thanks!
Thanks!
