I am having a strange problem with a new system I built using an Asus P7P55D-E Pro motherboard and G.Skill Ripjaws F3-12800CL7D-4GBRM RAM. I have four G.Skill memory sticks for a total of 8 GB of RAM.
The processor is an Intel i5-661 (dual-core). The OS is Windows 7 - 64bit.
The problem I am having is that when I start the computer up in the morning (cold) I started getting a Windows blue screen of death (BSOD) prior to the login screen. As a result, I have to use my system repair disk to fix the problem. The BSOD event does not create any Windows DMP error file.
After a bunch of debugging I discovered that the problem only happens when the computer starts up "cold". Note that when the PC does start and I can login to Windows 7 I have never had a BSOD or memory failure.
Using memtest86(+) I ran a memory test (1st six tests) when my computer started up cold.
On test five I saw that the memory had failures. Additional failures happened on test six.
I tried to trouble-shoot the specific memory module(s) by rotating positions but the failures went away.
When the computer was left off for several hours and I ran memtest86(+) again - I got errors on test five and six.
It appears that I was getting errors on all four memory slots.
I doubt if all four memory modules would be bad so I am thinking that it is either a memory configuration problem or the motherboard is bad.
It is tricky though because I never have any errors once the PC starts up into Windows 7. I have run the PC for two days before shutting down and never have an error. So the problem is just on a cold start up.
I am letting the motherboard automatically configure the RAM settings. In fact, this Asus motherboard has a button on the MB that does a RAM test and configuration so I ran that on board test after installing the RAM modules.
Does this sound like a bad motherboard? Or is it just a configuration problem?
Should I try to manually configure the RAM instead of using the motherboard "auto" settings?
