I'm having some difficulties with a setup I've built. Here are the specs:
M4A785TD-EVO
F3-12800CL9D-4GBNQ (X2 so 8GB total)
AMD Phenom II X4 Black Edition 955
Overlocked settings:
tCL - 9
tRCD - 9
tRP - 9
tRAS - 24
DRAM Frequency - 1600
DRAM Voltage - 1.6V
I haven't adjusted the HT or NB voltages, they are at default.
I'm getting blue screen of death after about 2 days of use. It will then persist. Installing Windows 7 64bit will also produce an occasional blue screen.
Do I have defective ram or moberboard? I'm getting these blue screen without adjusting ram bios settings, and also with adjustments for 1600. I know that this ram isn't listen on Asus's compatible list for the MOBO, but I have seen other posts on here and newegg reviews of people with the same config.
Any thoughts? Much appreciated.
James
M4A785TD-EVO
tCL - 9
tRCD - 9
tRP - 9
tRAS - 24
DRAM Voltage - 1.6V
James
