I need help - wrong bios settings?! Lot of BSODs!!!
  • I need help - wrong bios settings?! Lot of BSODs!!!
    GA-790FXTA-UD5 - F2
    F3-10666CL7D-4GBRH - AT SLOTS 1 2 - UNGANGED
    PHENOM II 955BE - C2 REVISION
    ZALMAN ZM850HP
    NOTHIN' OC
    [IMG][/IMG]
    AND THANKS FOR HELPIN'!!!!
    Please update the BIOS. The latest one will solve many bugs.
      I'll update it and see what happens!!! But, how about bios settings?! Are they right?!
      Thanks a lot!!!
        Row Cycle Time may be too low, I would suggest leaving all advanced timings to AUTO. You will only need to set the 7-7-7-21.
          Ok. First I've set all to defaults and then set the 7-7-7-21. Row Cycle Time is default set to 33, should you suggest another one?! By now, I'll test stability for two, three days. No more BSODs... I hope so!!!
          Thanks a lot one more time!!!!
            Hello. A bad module ram was the cause of BSODs... I tried one alone... then other, and BSOD came from just one of them...
            Updated system spec:
            GA-790FXTA-UD5 - F3F BIOS
            AMD PHENOM II 965BE - C3
              Send it in for a new replacement and that should solve your problems.
                I'll do it.
                Thanks for reply!!!
