Model of the motherboard: Gigabyte 790xta-ud4
Model of the memory: f3-12800cl9d-4gbnq 2x2Gb
Model of the CPU: AMD Phenom II x4 965 BE 3.4Ghz
I was reading the sticky about problems with the memory controllers on the Phenom II. Does this apply to the 965 BE?
What are the optimal settings for my setup? I have set it to 9-9-9-24 on 1600 unganged with the voltage at DRAM voltage at 1.5v. What other settings should I modify?
I have been having trouble running 3dmark06 all the way through and was told that RAM can cause the error I'm getting. "Device driver has failed and recovered." I am running Windows 7 64 bit if that helps you at all. I have tried running as 1333 and 1066 and it didn't make a difference. I also ran Memtest 86+ 4.0 with no errors and Windows Memory Diagnostic with no errors. Pretty sure the RAM is ok just want to make sure I get my BIOS settings correct for this setup.
Thanks,
Jacob
Thanks,
Jacob
