Settings Timings / Volts
  • Settings Timings / Volts
    I have this RAM:
    http://www.gskill.com/products.php?index=243
    MOBO
    http://www.msi.com/index.php?func=pr...1&prod_no=1740
    I am trying to set the timings and volts and MHZ in the BIOS. I have found where to change the timings and MHZ but when I click on DRAM voltage control it only goes down to 1.61v then it goes back to AUTO it goes up to 1.65v Gskills website says that this ram needs 1.6v which one can I select?
    Please let me know
    1.61V will be fine.
      Hi
      Thanks for your reply.
      Could I leave the RAM voltage on AUTO or is it best to change it anyway?
      Please let me know
        You will want to set it since on AUTO it can be anything it wants to be.
          Hi
          I have now changed the voltage. Should I use 1T or 2T command rate?
          Please can you let me know
            Command Rate should be 2T, but if it is stable at 1T you can leave it at that since it is faster.
