Witch memory do you recommed for P55-GD65?
I've read tons on google on P55 with memory of different manufactures that doesn't meet specs and doesn't configure correctly at auto, and when set manually gives a unstable system. Raising of voltages that might be dangerous and so on. So witch kit is the right one for me?
I've only got one requirement and that is stability, I don't plan to OC but might OC eventually after a few years.
Thx in advance,
Flatsix
P.S. I've read some things about upping the core to 1.35v to use some 1333Mhz memory kits at there rated specs? Why is this neccesarry if you don't overclock?
Thx in advance,
Flatsix
