Trident Heatspreaders
  • Trident Heatspreaders
    In the dead center of the heatspreader there is a threaded hole, what is this for? is there a waterblock or fan unit that can utilize these holes?
    http://valid.canardpc.com/cache/banner/1066980.png
    wow, no1 knows what its for? do tech's moderate this forum?
      GSkill's folks are here M-F (though they do pop in on weekends sometimes, which set do you have, some come with a fan
        i have the f3-16000cl9td-6gbtd running at 6-7-6 18 1600 / 7-8-7-20 1866 my kit didn't come with a fan unit.
          do the tech's have any input? if there is a factory made cooling add-on id like to know about it.
            i'm guessing the tech's are stumped? i've always applauded gskill for actually having true techs, where most other company's have "book readers" you know the type, wouldn't know one socket from another, when i think of tech support i think of some1 that knows the in's and out's of their companies products and has tinkered with them, not someone who reads from a set "tech sheet"
              No, unfortunately it is just the way it was designed. There is no factory made cooling.
