Blue screens on initial power up
  • Blue screens on initial power up
    Motherboard; Asrock P55 Extreme
    Cpu: I5-750
    MemoryG.Skill 2X2 F3-10666CL8D-4GBRM
    Power Supply: OCZFTY 700
    Video: XfX 5850
    OS Windows 7 64 bit
    Upon the initial power up in the morning I get the BSOD as soon as Windows finishes booting. Windows is unable to recover. A forced power down and repower back up and everything works fine. I can cycle power all day with no problems. Next day, same thing all over. The errors are paging errors, execution errors, memory acess errors etc.
    I replaced the Power supply -no help.
    Have run Metest86+ for 4 hours - ok.
    Run chkdisk - ok
    Memory timings are set to default 8-8-8-24 1.5 volts.
    I have seen similar complaints on other forums with the same ram and after replacing it with a different brand, the problem went away. After spending 3 weeks RMAing the PS and troubleshooting time, I am past New Eggs 30 day limit.
    Any idea's?
    Simply RMA the memory through us and we will be able to send you a new replacement set.
    http://www.gskill.com/rma.php
