Hello
My system is this
F3-12800CL8D-4GBTD
FOXCONN BLACKOPS X48 bios P05
Intel E8600
My issue is that I can not get stable with this ram at 1600.
I have been able to run 1000-1500 with 1.65 volts.
My timings are set to 8-8-8-21-60 T2
My mb and cpu are water cooled.
I do not know what other info is needed.
Yes to run 1600 on my memory I need to overclock.
My cpu will run 4.4Ghz on my old P45 board 100% stable.
I my system is stable at 500x8.5 4.25Ghz with the ram at 1000mhz or 1333mhz.
But not stable with the memory at 1600mhz.
I have tryed 400x10 4Ghz cpu and 1.6Ghz on the memory but is not stable.
If I run 333-370x10 on the cpu, setting my memory to 1333-1480 my system if 100% stable.
Could it just be this ram is no a good match for this board?
My system is this
F3-12800CL8D-4GBTD
Intel E8600
