I have a purchased the following components and I am running into major system stability issues.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL8D-4GBHK - Retail
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard - Retail
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX - Retail
I built the system about a month ago. When I first booted the system and entered the bios to configure everything the bios locked up. I searched on your forums and found a lot of talk about the memory speed and timings problems with this RAM and AMD Phenom II's. After letting the system sit for a few minutes I was able to return into the bios and sure enough the Bios detected the timings as 9-9-9-24. I changed the timings to 8-8-8-21 and left the clock speed at 1333. After that the system was stable and I was able to load Windows 7 64 bit. Since then I have not had anymore problems until yesterday. Windows just freezes and I am having problems getting into the Bios without the system freezing. Finally, I was able to get into the bios and change the clock speed to 1066 but that has not helped.
I have since downloaded memtest86+. I pulled the second ram stick out and tested one ram stick. I let it run for 1 complete cycle and it passed and no errors were found. I pulled the first ram stick and put the second ram stick in the same slot as the first. Memtest loaded but never completed before the program froze. I replaced the second ram with the first and rebooted the computer. When the system posted I pressed "delete" to enter the bios but the system froze again. I rebooted again and was able to enter the bios and exit into windows. The computer ran for several hours with one stick of ram.
With both sticks of ram in the computer, after a freeze I cannot reboot the machine immediately. When I restart the machine after a freeze everything inside comes on, there are no system beep errors, but there is nothing on the screen. I have to wait a few minutes with the computer off before it will post.
edit: the latest bios was flashed to the mb and the memory is listed as being verified to work with this motherboard as per gigabyte's spec sheet.
Please advise.
Thank you for your help.
Please advise.
