Hi all,
I plan to set up next week a system with the following components:
F3-12800CL7D-4GBRM (1600MHz, 7-8-7-24, 1.6-1.65V)
Intel i5 750
Gigabyte GA-P55-UD4
My question was this, I know at stock the max memory speed is 1333MHz (10 x 133 BCLK) so I was wondering what settings I could try for the Ram while leaving the processor completely stock (I don't have a need to OC yet, not until my new GPU at least).
So, basically my goal is:
1333MHz
7-7-7-21 (or thereabouts)
and as low of voltage as possible
I know every memory set varies and I will test my settings with memtest86+ 4 and prime95, but I was wondering if anyone had any pointers or knew of any good starting points that work for most. Also, beyond the four main latencies I don't know much about the others, so any other feedback/tips/tricks would be much appreciated.
Thanks again, and this is a really nice forum you all have.
Intel i5 750
Gigabyte GA-P55-UD4
1333MHz
