I have been unable to get F3-12800CL7D-4GBECO to run at 1600. It runs fine at 1333. WHat settings should I use for this RAM on the ASUS P55D Pro?
Settings for F3-12800CL7D-4GBECO on ASUS P55D Pro motherboard?
Got it!
Ai Overclock - Manual
CPU Ratio - 18 (20 is stable as slight overclock)
BCLK Freq - 160
PCIE - 100
DRAM Freq - DDR3 1600
DRAM Timing
RAS to CAS - 7
RAS PRE - 8
RAS ACT 7
RAS to RAS Delay - 24
CPU Fixed 1.3 Volts
IMC 1.2 Volts
DRAM Volts Auto
CPU PLL Volts 1.9
Rest to AUTO
Ran PRIME95 for 24 hours and was stable.
Manually set your memory voltage to 1.35 in the BIOS and adjust your BCLK Frequency to 160. Doing so will overclock your CPU.Work-in-progress
AMD Ryzen 7 1700X
Arctic Cooling Freezer 360
Asus Crosshair VI Hero
32GB (4X8) F4-3600C15D-16GTZ - G.Skill took too long getting their act together with their RGB RAM!
2X Sapphire Nitro+ RX 580 8GB
Samsung EVO 960 500GB
3X Seagate 3TB SATA3/7,200RPM
LG 16X Blu-Ray/DVD Writer
SilverStone Strider 1200 Watt
Phanteks Enthoo Luxe Tempered
So what's the consensus on these, are they decent OC'rs for 2x 2GB PC3-12800 parts?
Also if you under-clock them below stock, can you get tighter timings, & can they run on even less voltage?
I mostly want to run at stock or under-clock w/tighter timings....
But on the rare occasion that I game, a decent OC (not hard core) would be nice too!
Thank-you.
I'd say they're better than decent! I'm running them on MSI's P55 GD80 with BIOS 1.7. Whatever MSI did, my system is running better than ever with (4 X 2GB) 8GB. Current settings are: (20 X 190) 3800MHz, 2:8 FSB, stock memory timings except command rate (1T) at 1.38V. At stock settings, you can easily get 6-6-6-20-1T out of them if you'd prefer lower timings.Work-in-progress
AMD Ryzen 7 1700X
Hmm sounds great, not sure I'd have quite as much luck with a GA-H57M-USB3 though
I believe the memory controller on the clarkdale's (I'm getting core i3-530) reverts back to the Core micro-architecture.
And of course a lot depends on the board and it's BIOS....Last edited by jalyst; 02-23-2010, 09:56 PM.
Yes but I'm on a notably different platform, I prolly won't get the same level of OC.
http://gskill.us/forum/showthread.php?p=16764#post16764
